Hi all,
I'm in the UK and I've just rebuilt my engine (1984 VG30et), when it came to the clutch I found a 250mm flywheel and clutch fitted with a T5 Gearbox. It seems in the us 84-87 cars came with 240mm clutch.
I have a 240mm clutch and the bolt pattern is different on pressure plate to my flywheel.
Does anyone have a diagram of the bolt pattern for the later Turbo flywheel to pressure plate so I could verify this is what I have.
Thanx.
Thanx.
