All my gear enter pretty good, but every time I release the clutch I feel a thump or popping. It a real power drainer, plz help, already replaced differential Mount. Still feeling it, didn't check the drive shaft but I will tmr, but wondering if any has come across the same problem/issue. Plz help
1987 z31 Clutch make a thump/pop feel when I release clutch, help plz
This is very common and mostly associated with worn out rear sub-frame bushings.
Bushing: http://store.acadianasportscars.com/su056-0012
R&R from xenon: http://www.xenonz31.com/crossmemberbushings.html
Originally posted by 88sinZ View PostThis is very common and mostly associated with worn out rear sub-frame bushings.
Added to build Tread list, thank you for the info .Mr88sin, you guys are the best!!! In the z31 forum... Loving this a lot, I get a lot of help.. Thx again brother
