I have recently purchased an 88ss (V-lsd for sale btw) and I'm going to put it's manual transmission in my 87na 2+2. I know i'll need to have the driveshaft lengthened. The engine is not original. The guy i bought it from said the transmission wasn't either. The clutch (a worn out ACT street with a broken pivot arm) had a 250mm disk. Does the larger clutch/flywheel surface mean that the transmission is the late 87+ turbo? Can anybody positively ID it by the pictures, or can somebody tell me of a way to ID it for sure? The transmission measured 35inches if that helps you ID it.
More importantly, how much longer does my driveshaft need to be? does anybody know how much longer a 2+2 shaft is compared to a 2seater with the same gearbox? I
