Car not the same
  • Car not the same
    check to make sure you install the throtle position switch correctly.If you did then u probally installed you t-belt wrong.
    1986 Current build
    HX35/40 60mm wheel,480cc injectors,nistune, spearco 2-221,6 puck,walbro fp,solid cross and diff,jason motor mounts,poly everywhere else.
    yep, sounds like the classic Timing belt f-up...
      do you have a vacumm leak. thats another symptom.
      the sierra club is gay!!!
        This happened on my 85 automatic, hit a random fuel/ignition cut at maybe 2000rpm. If i warmed it up a few past the lower line it never did it.
        I still shrug at this, Just told the guy i sold it to to warm it up.
