You could get the same thing I just sold to 2+2turbo. the AEM uego. it has a selector on the gauge(gauge is also the controller) to send a normal nernst cell signal to the stock ecu. meaning it will read 0-5 volt info on the gauge but the stock ecu will still read like its got a stock o2 sensor.
It says you can calibrate that to work with those sofware options. But it didnt say you can make it read like a normal 0-1 volt o2 sensor which by the way is opposite of the wide band sensors. meaning 0 volts =lean on one and 0 volts = rich on the other.
:shock:
*Before you get too excited...remember that there is a difference in the Titania and Zirconia sensors.
~For this "EXACT" application in question('87n/a)...everything will be just fine with the w/b outputting the 0-1volt signal to the ecu.
~The z31's that use the Titania sensors though, are different than the typical 0-1volt sensors...they work on a resistance rather than voltage, and this means that the w/b 0-1v output will not work with the ecu.
**How does this relate?
~If anyone reads this and mis-interprets the info already provided, I want to be sure that it is understood that the ecus using the Titania sensors will not work with what has already been suggested. Two sensors will be needed to be used. One for the W/B and the Titania sensor to feed the proper information(output) to the ecu.
The block style for your application doesn't even matter.
*I think you missed my point.
All '84-'89 Nissan 300zx cars use one of two types of o2 sensors.
*Which ones use what type of sensor?(look at this link) http://www.redz31.com/pages/fuel.html
The cars that are using the Zirconia o2 sensor will be able to accept the converted w/b output to run the ecu(meaning that the w/b sensor will be able to give you 2 functions from 1 sensor....wideband afr's and the narrow band output for the ecu)
The cars that are using the Titania o2 sensor, will need to retian the original(oem) o2 sensor for the ecu.(meaning that the w/b will only work for giving you the wideband afr's...because the Titania o2 sensors these cars use do not reference 0-1 volts, they reference the resistance within the Titania o2 sensor for output to the ecu)
If you have a wideband; Will a stock ecu stay in closed loop longer than stock as the throtttle position/gear/load/etc changes?
My thought is that the WB does stay in 'output' mode longer than a stock O2 sensor (of either type) might. This would result in a much different AF/timing response?
So is it desirable to have a closed loop car for all conditions? It might be if you can re-program the ecu for most closed loop conditions I suppose.
Dan-TSS wrote: The block style for your application doesn't even matter.
thanks for the info , Im learning some thing new every day , So that means i will be able to use any WIDEBAND o2 sensor ?
