Sensor error messages?
I know that when I bought mine, there was need to reload an updated release that cured some flaky error messages for the sensor.
*This was back when there was in depth arguement that the LM-1 cooks or goes through sensors. It is thoroughly explained in many different ways as to why and what was exactly happening with either the software reeleases or sensors in each particular situation. (It's all in innovates web forum) There's very good chance it could be one of two things...software release simply needs to updated or reloaded, or the sensor itself is wasted.
The explanations as to why?...search the innovate forum...these topics are always explained with terminolgy and reasoning that I can understand but have trouble repeating it the same manner as put there.
Go into the Light!....
8)
Bernard, I asked the exact same question on the innovate forum when I first started using mine...
*The answer is simple....What is diplayed is a slower sampling rate.
What is logged is proper/most accurate.
This is why tuning by read-out is ....ok, but not the best.
*I kinda hinted around this with recent PM's with Jason..I assumed he knew this.
8)
I actually noted no difference on mine. If it says 13.5 then it apparently logs 13.5... with the only issue being the digits on the screen are hard to read when they fluctuate rapidly from changing AFR.
Using another LM-1 this past weekend I noted that the AFR's we saw on the screen very very close or exactly the same as what was reflected in the logs.
So that's now up to 3 for 3 on my end, not having this issue.
The LM-1 does NOT come ready for RPM recording correct? You have to buy the rpm input cable and the inductive clamp(whatever that is?) Does the LM-2 kit come ready to log rpm? Is the LM-2 basicaly an LM-1 with rpm logging capabilities?
Correct the LM-1 will not by itself record RPM's.
The LM-2 I think and the LM-3 for sure will record RPM's to a laptop using the Logworks software. However you will only get A/F with the LM-1 and it will record the RPM's from the LM-2 or LM-3
