I am continuing my preps for this winter's mods and would like some feedback.
Before I go any farther I have to say thanks to Russ and Matt (darkhalf) for their help to this point. It is much appreciated guys.
I am getting NIStune and will use the NVSRAM instead of Romulator and I need to make a decision on LM-1. There are basically 3 options, Basic, RPM and AuxBox.
http://www.innovatemotorsports.com/products/lm1.php
My inclination is to just get the most capable/functional setup (AuxBox)from the start but need some feedback if its worth it or if I should just get the RPM kit.
I am thinking of adding a pillar 3 gauge unit with: A/F, Fuel Pressure and ??? back up engine temp??? (suggestions welcome)
Keep in mind I am sticking with NA so the whole turbo considerations are not in play. I know that goes against the grain but indulge me if you would. :wink:
