Im having a real hard time getting my car tuned. It runs and drive great and has plenty of power as you will see in the dyno graph, but I know I have a lot of work to do. The car is off the chart rich under boost and very inconsistent at low speed. let me first give some background on my car. I have a t3 turbine housing stage 3 wheel, to4e 54 trim. Peak power and torque was made at just over 20psi. 450cc DSM injectors and a Z32 AFM. Have a romulator and made all the necessary physical changes to the computer to use the new AFM. K value is 285dec (011Dhex) and null is 91dec (5bhex). The timing and fuel maps are a combination of stock maps as well as the maps from a BIN on Jason’s site. The lean AFRs are what I have changed to get the car to run at around 15.0 on the highway. The bottom line is I can not get the logged AFRs to match the map. I set the values of the fuel map to about 12.5 and tested and each time 285dec seems to work well. When I use that K with real fuel maps nothing matches up. I went so far as to manually type in the scale for the afm as well as calculate my own TP scales through hex. I did everything through hex editor assuming that some quirks in livedit may be my problem. I know im all over the place and rambling but ive really had enough. Im praying for the post that tells me how to get the new nistune because this shit sucks. Is there anyone within driving distance from long island that wants to make some money and do this for me? Dan, I would even take a ride up to you if you if you think you can get this fixed. sorry for the long rant and the big pics, but if i shrink the dyno sheet down with my crap software you cant read it. Anyway, this is more of a complaining session than a question, but if anyone has any comments I would really appreciate it. thanks
Take a look at how the AFRs are completly off the chart, especially during the first run
the car idles at 12-1 but sometimes it brings itself to 18-1 and then comes back to 12.. it does the same thing whether the O2 is plugged in or not.
i thought i heard pinging so i loved the top end timing. thats the least of my problems
