JWE HI PO ECU's
  • JWE HI PO ECU's
    Are they really worth the $500.00?
    If thats what they sell then for i guess so. j/k
    Depends how mechanically inclined you are. If know how to work on your car and understand the concept of what air/fuel and ignition does for your car. Then u should look in to romulator on redz31.com please read all that is on that site.
    1986 Current build
    HX35/40 60mm wheel,480cc injectors,nistune, spearco 2-221,6 puck,walbro fp,solid cross and diff,jason motor mounts,poly everywhere else.
      Personally I would recommend Nistune. The down side to that is you may have to wait a couple more months.
      Check out the Nistune threads and you will get the idea of why I am recommending it over JW.
      Performance costs money.
        "It pretty much works but I need to get it all checked before i get a batch of them made up. Those will be about a month or so off depending how much free time I get "
        the nistune guy (matt) said this on september 28th. i was under the impression that they would be ready for sale any time now. do you have some kind of insider information, or are you just assuming it will be a couple more months? if it is definetly going to be a couple months then im going to have to spend some time screwing around with livedit which i DONT want to do.
