(1) I would stick with your 87 N/A ECU and put a 87 turbo ROM on the NIStune board. The only thing is you miss out on knock sensing (N/A ECU not fitted with knock sensing board)
The 84 ECU although turbo is really old and although they run. I prefer not to use these. Also have to check O2 sensor compatibility etc if you did use that
(2) You can change your injectors etc. NIStune adjusts the amount of fuel injected (flow and latency) in addition to changing cells on the fuel maps
(3) Shipping according to Australia Post is 8 working days overseas to US (so really about two weeks judging from feedback) which is about $10AUD to send (not tracked)
Anything like express post (3 days) tracked is going to cost about $45AUD upwards. You can almost send something as heavy as an ECU for the same price
