Yeah this is a really great forum. Probably my favourite 300z forum for sure!
Another reason I made those butterfly washers was when I was milling the inside of the plenum, gutting it out.
I cut right through the casting by some of the runners. For some reason, I guess...depending on where some of the manifolds were made, the mould was a bit high underneath the plenum by the runners.
So, those washers were to also cover up those breaks. I wanted to mill the bottom of the plenum flush with the rest of the manifold. But after I started breaking through a couple spots. I figured I would just keep it as it is.
