http://www.autospeed.com/cms/A_2418/article.html
Read how it works
Some Clever Australlians came up with it
I have bought the kit and made one for my own Z,for my situation its a good solution to get a good tune from the mods of cams ported heads and 3 or so psi more boost on a stock fuel system(Nb will be using uprated fuel pump and higher base pressure).
Of course this has to be used in conjunction with a Wideband 02 setup, which i also intend to get
Read how it works
