They seemed to think the MBC was not only effective, but BETTER than some of these expensive electronic controllers.
ive read that before and i read it again.. its a joke. they talk about this fancy datalogger they have and they dont bother to post the results. they complain about small knobs and poor instruction.. when it comes to functionality they just say "no better than a manual" or "it works great".. if they are going to make such a claim then they should show a graph with MAP and rpm for each BC that they tested. lets see some numbers. ive used many MBC's on many cars. ive used name brand and homemade. ive only used one EBC(profec b) and i will NEVER go back to a manual. they are crap compared to an ebc.. i would LOVE to see some actual data on this topic
All I can tell you is that a shitty MBC blew my rings....
If you're going to get a MBC, make sure it's decent quality.
How the hell is it the boost controllers fault that you blew your rings? because it spiked? sounds like opperator error to me.
Well, I am definitely partially to blame. However, the fact that the MBC could not be set to anything below 15psi was not my fault. Even after I cut the spring it would not open earlier.
