not sure if anyone else has done this...
  • not sure if anyone else has done this...
    I finaly got the car running again after snapping the #2 cylinder intake valve and punching a hole in the piston. But thats another storry
    Well, I ended up playing with those little solenoid vaccum things that sit by the coil and I rigged one up to a toggle switch so it can be used to switch between stock boost settings and a manual boost controller. so far it seems to work out pretty well. Just thought Id share.
    OrionMCP wrote: I finaly got the car running again after snapping the #2 cylinder intake valve and punching a hole in the piston. But thats another storry
    You mean the solinoids for the fuel pressure regulator? I'm not sure which ones you are talking about.
      the ones that are screwed onto the bracket the coil attaches to. I tried to post some pics on here but the photo gallery dosent like me. I guess thats what they were there for originally.
        Haha, that sounds like a cool idea. Home made EBC
          it's been discussed several times, basically you use two ball spring boost controllers set to different psi, then add a vac solenoid and switch to toggle which is the boost reference, the higher or lower one
          you can use it for a simplistic 2-stage launch control, or just having electrical control of a mbc to keep the hoses really short
            G-E wrote: it's been discussed several times, basically you use two ball spring boost controllers set to different psi, then add a vac solenoid and switch to toggle which is the boost reference, the higher or lower one
            News to me. Sounds like a cool idea, especially if your boost spikes for some reason.
              great idea man.. a while back i was thinking that there must be something interesting that can be done with those things sitting on a shelf collecting dust.. unfortunately i have no imagination.
                ok. i just cant upload pics from my computer? well here it is.
                  Hey yeah, that's a cool old school mod. I think obso was doing that on his car and using the adjustable suspension switch for that and nitrous control. I've been saving as many of the air solenoids from AIV and FPRS, EGR, as I can.
                  s - slow - low boost
                  n - normal - high boost
                  f - fast - high boost +nitrous
