before i got those readings i rigged up a one wire o2 sensor to the ecu pin out for it so i beleive i have some o2 control . it doesn't seem to make much of a deference when i change the k unless i go big like 20 to 30 k .
now i feel like a fucking retard
jjewell wrote: what should my afr be around at idle i've got it hanging around 11.5-12.0 anything leaner and it's rough . but it is also idleing high at about 1100 rpm.
Do you have the TPS connected? If so, disconnect it and see if there's any difference.
ok i got to spend so time on the car today . when it's running rich it idles pretty well with afr's around 11.5 . as i reduce the k i can get it run around 13.5 but within a few seconds it starts to run real shitty and the afr's go from 12-14.5 up and down . i left it run like this for a while and played around with the timing and few other sensors but nothing makes that big of a difference. this is really getting old and i know it's going to end up being something stupid .
boost. does a body good!
