-11. PSI ~= 22 inches Hg
I think that's what was going on with the conversion. Also, from the innovative forum the autometer map sensor puts out 0-4.5Volts not 5 volts.
from the manual:
Function 4 of input 4 of the DL-32 measures vacuum and boost pressure with a range -14.7 to 29.4 PSIg This is the range intended for boosted engines where the maximum intake pressure can be up to 29.4 PSI above atmospheric pressure.
Vacuum is typically measured here as negative PSI.
But you can set up any metric you want with LogWorks 2.
from the manual:
