I'm starting my Dl-32 install (glorified Aux Box). XD-16 and LC-1 ...
See my progress at: http://www.mygen.com/users/dbruce/myz31 ... nstall.htm
I am in a bit of a quandry over where to put the dl-32. The serial cables for the xd-16 exit down at the fuse box area reaching to the firewall. So thats the easy spot.
However it might be possible to put the box over on the passenger side above the ecu (still need to check if it can fit, anyone tried?).
The box has to sit horizonal and square for the accelerometer. Problems mainly are with the wiring, this includse power (tap from the ecu?)/ground (same), LC-1 wires , tach signal from MSD, want to use the Autometer electric boost gauge signal wires (drivers side)....
Pluses are access to tapping any ecu wires at hand, speed sensor signal, etc...
Has anyone installed an auxboxc in the engine bay?
Thoughts and suggestions would be most appreciated.
