What plug gap do you run?
Well I use 95 octane daily, 98 when I have extra coin to burn.
What's the stock gap in inches, is it infact .040? I was just making a guess there...
( RON Octane Rating x 0.95 = AKI Octane Rating )
98 RON Octane x 0.95 = 93.1 AKI Octane (US measure)
100 RON Octane x 0.95 = 95 AKI Octane (US measure)
Seems as if you're right, I use 105 octane when I can but god that stuff is expensive....
Anyway, stock plug gap in inches, anyone?
I couldnt find it in the Haynes manual which is all I have, I have the details for metric which is 1.1mm and 0.44 is very close to that so it sounds about right. Just wanted to make sure so I can actually use the information in this thread about plug gaps lol
actually it's more complicated than that, each fuel "tests" differently, so while two fuels may both be 98ron, one might be 2-3 MON points lower than the other
but as a guide I think you're right
I run a .32 gap with stock boost (7 psi). This was to compensate for the POS junkyard electronics from the 1981.
Would I see an increase in performance if I went up to .43? I generally don't wind out the motor too much because the rubber in the harmonic damper looks iffy.1976 280Z 2+2 Turbo
'81 L28ET, '84 Turbo ECCS, '84-'85 rotors + Toyota 4x4 front calipers + 240SX rears, Z31 DXD Stage I clutch kit, Evo intercooler, Tokico lowering springs and HP blues
"I drive an S30...your stock equipment is my future upgrade!"
I doubt you would see any better performance, the only thing that might improve is the idle. They told us at school it is harder to ignite the mixture at idle with a short gap, that is why most stockuse the biggest gap they can run without blowing out at high RPM.
BTW, for everyone else, stock gap is supposed to be .043" by the manual13.729 @ 102.90
http://z31.com/board/print_profile.php3?user_id=872
