Nothing else to do when it's 20 degrees outside except play in the garage. I made some fuel rails in 20 minutes (that's just a poke at an earlier post by someone else)... It has been more like 2 weeks, with working on them 10 minutes here and 20 minutes there.There was a set of 390cc fuel injectors laying around my garage and I decided to try my hand at a little fabrication. I only have the right side put together (still need some finish & touch-up work on the brackets/intake and install Earl's/Russel/Aeroquip line fittings) for now. There isn't more than $50.00 in parts (not including injectors) for both sides, but I can see where the time involved could be costly! I also milled out the lower injector mount in the intake manifold to drop the injector pintle lower into the intake runner to put it as close to the factory injector pintle location.
Any input or questions from you other fuel rail guys may be helpful!
