SAFC DIY?
  • SAFC DIY?
    I saw that some people were requesting it. Is it really needed around here?
    The SAFC is good for tuning the gap between the stock ECU/injector limit of ~240whp up to the ~320whp MAF limit. After that, you'll need a bigger MAF or bypass, and the SAFC will no longer be useful. But the SAFC is super cheap and takes less than an hour for any noob to install once the DIY is done.
    I just bought an SAFC for $85, and can do a quick writeup with pics if you want. I'm a newb to the Z31 ECU though, so if any of you have a pinout anywhere, then let me know.
    1987 300ZX Turbo - http://www.z31performance.com/forum/vie ... php?t=3114
    Subject: 84 NA ECCS Pinout
    Subject: 84 normally aspirated computer pin out
    84NA ECCS Connector
    pin/wire color/destination
    1 X
    2 L..........FICD/Idle up Solonoid
    3 L..........Ign Coil, Pwr Trans
    4 L/W.....EGR Control Solenoid
    5 G/B......Pwr Trans
    6 R..........EFI Relay
    7 X
    8 G/Y.....CAS (sheilded)
    9 Y..........Ig Switch, G/Y to Pressure Reg Con Module
    10 X
    11 G.......Unused Connector
    12 R/W. AFM
    13 X
    14 X
    15 Y........Fuel Temp Sensor
    16 B........Air Reg
    17 G/B....CAS (sheilded)
    18 P/L.....TVS
    21 X
    22 Y/G.....A/C System, Headlamp Switch
    23 Y/G.....Pres Reg Con Modulator, CHTS
    24 B.........Oxygen Sensor (sheilded)
    25 L/G......TVS
    26 B..........CHTS, AFM
    27 B/W.....Pin #35
    28 B..........Pin #36
    29 X
    30 Y/G.....AFM
    31 B.........AFM (sheilded)
    32 X
    33 X
    34 G/W...Ig Coil, 15A Fuse in Fuse Block
    35 B/W...AFM (sheilded), FICD/Idle up, EGR Con Soleniod, CAS (sheilded), L/R to Pres Con Reg Solenoid, G to Pres Reg Con Mod
    36 B........Bonding Wire for Sheilding, CAS (sheilded), Pressure Reg Con Mod, Unused Connector
    101 G.......Injector #1
    102 G/B...Injector #3
    103 G/L...Injector #5
    104 G/Y...Injector #2
    105 G/R...Injector #4
    106 G/W..Injector #6
    107 B.......Ground, FICD Soleniod Valve; Pins #109, 112, 113
    108 B.......Fuel Pump Relay (sheilded), Fuel Pump (sheilded)
    109 B.......Same as #107
    110 X
    111 X
    112 B.......Same as #107
    113 B.......Same as #107
    114 R.......Fusible Link, Injectors
    115 Y.......Pres Reg Con Modulator, Oxygen Sensor
      84 turbo computer pin out
      84T ECCS Connector
      1 X
      2 L..........AAC
      7 X
      10 X
      12 R/W. AFM
      13 X
      14 X
      16 B........Air Reg
      18 P/L.....TVS
      21 W........Detonation Sensor (sheilded)
      22 Y/G.....A/C Relay, Headlamp Switch
      25 L/G.....TVS
      27 B/W.....Pin #35
      29 PU.......Combo Meter (Vehicle Speed Sensor)
      30 Y/G.....AFM
      32 X
      33 X
      35 B/W...AFM (sheilded), AAC, EGR Con Soleniod, CAS (sheilded)
      102 G/B...Injector #2
      103 G/L...Injector #3
      104 G/Y...Injector #4
      105 G/R...Injector #5
      110 X
      111 X
        86 computer pin out
        86 ECCS Connector
        1 R..........-not used-
        2 L..........AAC valve(T), Idle-up solenoid(NA)
        4 L/W........EGR Control Solenoid
        5 G/B........Pwr Transistor
        7 SB.........To Combination Meter (digital type)
        8 G/Y........CAS (shielded)
        9 Y..........Ign Switch
        10 BR........Neutral Switch(M) or Inhibitor Switch(A)
        11 G.........-not used-
        12 R/W.. ....AFM
        13 -no pin-
        14 Y/G.......AIV Solenoid
        15 Y.........Fuel Temp Sensor
        16 B.........Air Reg
        17 G/B.......CAS (shielded)
        18 P/L.......Throttle Valve Switch
        21 W.........Detonation Sensor (shielded) (T)
        22 Y/G.......to A/C system(NA),pwr steering sw (NA),
        .....FICD solenoid valve(T),AC compressor relay(T)
        23 Y/G.......CHTS
        24 B.........Oxygen Sensor (shielded)
        25 L/G.......Throttle Valve Switch
        26 B.........CHTS, AFM
        27 B/W.......Pin #35
        28 B.........Pin #36
        29 PU........Combo Meter (Vehicle Speed Sensor)(T)
        30 Y/G.......AFM
        31 B.........AFM (shielded)
        32 -no pin-
        33 -no pin-
        34 G/W.......Ign Coil, 15A Fuse in Fuse Block
        35 B/W.......Pressure Reg. Control valve, EAI solenoid, EFI Relay, EGR control ...solenoid, CAS (shielded), Idle-up solenoid (NA), AAC valve (T), AFM
        36 B.........Bonding Wire for Shielding, CAS (shielded), CAS, body ground
        102 G/B.....Injector #2(T) Injector #3 (NA)
        103 G/L.....Injector #3(T), Injector #5 (NA)
        104 G/Y.....Injector #4(T), Injector #2 (NA)
        105 G/R.....Injector #5(T), Injector #4 (NA)
        106 G/W.....Injector #6
        107 B.......FICD Solenoid Valve(T & NA), Pins #109, 112, 113, body ground
        108 B.......Fuel Pump Relay (shielded), Fuel Pump (shielded)
        110 -no pin-
        111 -no pin-
        114 R.......Fusible Link, Injectors 12+ source
        115 -no pin-
        Notes:
        1 most control voltages seem to be negative such as fuel pump, injectors and the Ignition coil. Because of this, a good ground is important!
        2 The injector wiring difference between T’s and NA’s might be a contributing cause to hesitation’s after the injector campaign. There is not much of a difference between the T and NA’s wiring, most notably the difference in wiring of the FICD and AAC valve on the T’s and FICD and Idle-up solenoid on the NA’s.
        3 not many differences between the 84 and 86, notably the lack of the fuel pressure regulator control module (pin #115). Also noted are the lack of the headlight switch (pin #22) which probably effects the idle speed and the addition of the AIV (air injection valve) on the 86 models.
          Feel free too search next time.
          z31.com
