I'm still not convinced these things are worth the money, but mine was free as it came on my 87T :-D
I did notice a small difference in low end power, and I should be able to tell if it made any difference in fuel economy when I drive to the other side of the state this weekend.
I built a little mounting plate for it out of 1/4" 6061 aluminum (it's super strong! LOL). Currently only the MSD, boost control solenoid and power transistor are mounted to the plate, but I left room for future additions should I decide to get them (tach adapter and 2-step perhaps?). I cushioned the entire plate by placing some small rubber bushings under it, so shock and vibrations won't be an issue.
The coil is mounted to a stock coil bracket which I cut and drilled to fit the Blaster SS coil.
Edit: Another pic.
Edit: Another pic.
