Maybe somebody here can help out as well.
http://ecu2.forumwise.com/ecu2-thread1679.html
Later, after submitting that post, I realized that changing the 02 sensor feedback won't effect my timing. I did find a 16x1 address in the BIN for base idle timing, which is then modified from other sensor inputs. It starts out at 15degrees and then moves its way up to 27 degrees. I've thought about raising the lower settings and seeing what happens.
