z
Methanol injection
methanol injection
An update; first problem found was a air leak between MAF and compressor intake, second was a boost leak, and i regaped the spark plugs to .028 and readjusted the methanol injection using winter formula washer fluid :shock: wow 15lbs of boost no inter cooler no knock .Black 1986 300zx Turbo coupe (Chuki)
http://z31performance.com/showthread...86-Turbo-Coupe
http://z31performance.com/showthread...9;s-1986-300zx
I tried meth once... stayed up for hours and hours... didnt try it again.BLOZ UP.com
