someone I know is selling a MAP ecu....
  • someone I know is selling a MAP ecu....
    the name being MAP and uses you guessed it a map sensor, it also has facilities for datalogging wideband o2 apparently, uses nvram, computer programmed
    it's a piggyback in the sense that it replaces your afm with a map and outputs to the ecu accordingly 0-5v .... it can emulate both gm frequency type and normal afms
    so basically it's like a super-mega safc for about the same money
    *edit* just to be clear if someone wants it I can get it for about $300, but I'm waiting for nvram nistune
    There are many versions, which one is it? I've heard some great things about them.
      that I don't know (version) but is the hw different or just sw? I mean if all you need is an updated cd....
        Chuckle chuckle
        I've heard some great things about MAF sensors too...
        It's RWD in reverse.
          Re: Chuckle chuckle
          j30_vg33et wrote: I've heard some great things about MAF sensors too...
          I also find it a little funny when people tout speed density as somehow being "superior" to mass air flow.
