Bump - whatever happened with this problem? Need follow up
Hey - my car runs noticeably different when the max fans kick on, sounds very similar to your problem. I don't have afr logging so I can't tell exactly what its causing. I am using JWT with cobra MAF. Did you ever figure this out? I might exercise my new meter by measuring maf output before and after fans kick. I am pretty sure my shield is still grounded properly.
unfortunately, I don't really have the option of going back to a mechanical fan setup, tried to and failed already. The spearco piping is just impossible to work with if the shroud is there.
