7psi??
  • 7psi??
    Well.. here's the situation -- I can only get 7 psi of boost.. I haven't pressure tested my plumbing so it may be the problem but I was wondering if it's possible i'm running too rich? I'm hitting an afr of about 9.5 at 7 psi... so.. is that a possibility... i have worries of detonation so I'm not eager to really push my tuning untill i get a proper knock sensor. oh yeah.. by timing is at 21 degrees at that point.
    eagle rods
    38 mm external wastegate
    mild port/polish
    3 angle valve job
    custom intercooler piping
    rad moved back
    romulator
    420cc injectors
    I dont even think the knock sensor does anything if you're controlling the boost by other means such as with an electronic or manual boost controller.
    88T => 300zxt
    http://www.300zxt.com
      9.5 is so rich I am shocked your engine will even fire. My engines won't run under boost richer than about 10.5, it sputters and backfires.
      Don't add extra fuel to kill the timing, adjust the timing maps or base after you've got the fuel set where you want it (high 11's for a high-boost street car).
        hehe... it was running at 8.3 earlier yesterday... i'll try and get the afr's up to 11.5.. but my k value already seems awfully low -- 0100hex. I am going to re-calibrate my wideband and double check everything today.
        eagle rods
        mild port/polish
        3 angle valve job
        rad moved back
        romulator
        420cc injectors
            AWESOME info! thanks Bernard! I'm going to have to change the latency then as well i suspect... afrs are kind of weird and don't correspond to the map at all.. if i get it lean at idle then things don't work so well under boost... so i suspect my latency is slightly out. And I'm pretty sure my $40 BOV is causing me issues... I heard it bypass once today while at about 7 pounds of boost. However, I have managed to get the boost to 10 psi -- I found a couple of minor leaks that i was able to fix.
            eagle rods
            mild port/polish
            3 angle valve job
            rad moved back
            romulator
            420cc injectors
              t70 wrote: AWESOME info! thanks Bernard! I'm going to have to change the latency then as well i suspect... afrs are kind of weird and don't correspond to the map at all.. if i get it lean at idle then things don't work so well under boost... so i suspect my latency is slightly out. And I'm pretty sure my $40 BOV is causing me issues... I heard it bypass once today while at about 7 pounds of boost. However, I have managed to get the boost to 10 psi -- I found a couple of minor leaks that i was able to fix.
              What BOV do you have? I bought a cheaper HKS knock off on Ebay a little while back and while it looks identical and they claim it really is an HKS, there's no way I could have purchased a legit HKS unit brand new for $65. I'm just a little worried that it may give me problems as well.
              545 RWHP & 540 RWTQ
                http://cgi.ebay.ca/BLOW-OFF-VALVE-UNIVE ... dZViewItem
                .... That's the BOV I'm using. I am going to try and shim the spring.. but it would appear that the Bov is actually unpredictable. I have actually only heard it bypass once under boost, but I think it leaks randomly because my afrs sometimes are jumpy as boost increases and it shouldn't be from my map as it is fairly consistant.
                eagle rods
                mild port/polish
                3 angle valve job
                rad moved back
                romulator
                420cc injectors
                  t70 wrote: http://cgi.ebay.ca/BLOW-OFF-VALVE-UNIVE ... dZViewItem
                  How is your BOV mounted? Have you tried to test it without the BOV?
                  http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... %3AIT&rd=1
                  That's my BOV that I plan on putting on when I get my piping ready to install. I'm just leary of it leaking as well.
                  545 RWHP & 540 RWTQ
                    taht is a weird looking thing
                      WaZZ300 wrote: taht is a weird looking thing
                      That's what I said about yours. LoL.
                      545 RWHP & 540 RWTQ
                        Welll... I have not tried to run it without the bov. I'm going to try and pressure test my intercooler and make sure there aren't other leaks that i missed and then I'm going to shim the hell out of that bov. But first i've got to start working more on my map. As of right now though -- i'm back to work for 2-3 weeks so i'll be x-communicato for a while.
                        eagle rods
                        mild port/polish
                        3 angle valve job
                        rad moved back
                        romulator
                        420cc injectors
                          I have a blow off valve? SICK!!!!!!
