I finally will install my 420cc Benz injectors today. With the Z32-AFM swap i still want to wait some days until i have the impression that the injectors work well and next step can be done.
So i had two requests to the those here around who are also using the combination Z32 AFM and Benz-Injectors (stinky, ...).
1. your recommended K-Value with benz-injectors and stock afm, stock fuel pressure. (around ´260´?)
2. Your recommended K-value with benz-injectors and Z32 AFM, stock fuel pressure. (maybe your entire tables and values that have been changed?)
As this is my first time tuning a bigger afm and inj. by myself i hope i had collected enough theoretical knowledge to go for that, but if you could give me kind of a startup recommendation so that at least the engine will start and run clean having a base for fine and finest tuning.
Thanks
Thanks
