i have a msd digital 6 that has been sitting in my garage for 4 years now , has anyone used this unit before ? i just could never get it to work right . now that i'm having trouble blowing spark out i would like to get it working again and try the spark duration settings for a longer spark. if anyone has used this particular unit how did it work for you and did you have to do anything special to make it work. also does anyone have any pics of there install ? my old mounting brackets won't work with the current setup and would just a few different ideas for mounting.
msd digital 6
WOW THAT IS SEXXXY! I presume that is a standalone system operating that baby?8.5 custom arias pistons (.020 over)
eagle rods
38 mm external wastegate
mild port/polish
3 angle valve job
custom intercooler piping
rad moved back
romulator
420cc injectors
