Capacity of stock turbo AFM
  • Capacity of stock turbo AFM
    During testing with my new turbo the last days i found out that the stock AFM reads more power than i expected. Could bearound 300R-320 RWHP. Has anyone here around checked/analized that precisely?
    Dino wrote: During testing with my new turbo the last days i found out that the stock AFM reads more power than i expected. Could bearound 300R-320 RWHP. Has anyone here around checked/analized that precisely?
    I haven't tested it myself, but that sounds about right. I remember someone else getting very similar results in the past. Was this on a Dyno?
    545 RWHP & 540 RWTQ
      This was with a stock AFM
      http://www.ibconceptions.com/blackhawk/Aaron33LDyno.jpg
      imagination is a virtue
        no, i wasn´t on a dyno yet but i estimated the power by taking acceleration times. (Maybe 100 to 200 km/h on a flat road).
        @craZed: aha. the AF-curve is showing kind of a knee point @5200RPM. Above that the AF-curve is going constantly up. This could be the AFM-maximum.
        Thanks
          and or the 260s maxing out
            I had a feeling that was about the limit of the stock afm. I'll be testing that on the dyno once we get it up and running. What voltage are you hitting at that power level?
              Im sure I read somewhere that the stock AFM can be modified to meter more air... I can't remember where I saw it now, might of even been on Jason's page.
              http://youtube.com/c/zcartube
                Pretty much any maf could be modified to read more. How easy it is to do is the tricky part. On top of that you need to create a new VQ map to keep things accurate which is the real hard part.
                  well stinky, if you guys want to make some money, develop a nice 4" adapter that will bypass some air around the afm, and make that new vqmap, then sell the kit, if you use the stock afm then there's no worry about dropping resistors or modifying ecus ....
                  just a thought
                    a guy on hybrid put the mas in a 3.5 inch tube and the upgraded the injectors and then adjusted the fuel pressure untill it was right on. I know its the best way to do it but it worked.
                    tbs
                    Blue & Silver 81 zxt, 88 ECCS
                    Z32 mas,450cc injectors
                    ported exhaust manifold, cable throttle linkage
                    t3/t4e 12psi , 3inch exhaust, K&N,
                    ACT clutch, 240sx t/b, 1G DSM BOV
                    Custom Intake FINISHED
                    Ported and Polished N42
                    Tan 88-89 conquest seats
                    Sperco IC 18.5x6x3.5
                    2.5 IC pipes
                    Suspension work!!
                    Nistune
                    Zeitronix Wideband
                    240sx transmission
                    Soon:
                    95 Maxima Alternator
                        @stinky: hard to say because my tuning software shows 0,45volts @ idle and 3,81V @ 18psi and 5200RPM. I never achieved a higer value than 3,81V. But i am sure that should be 5 Volts or so(Maxvalue). I have to fix that software problem. But the AFM is defenitively maxxed out because Voltage is rising only minimal with a big increase of boost.
                        - 100% stock Z31turbo: 3,14v @ 5200RPM = 203hp WHP
                        - tuned z31: 3,42V@ 3600RPM @20psi
                        3,81V@5200RPM@18psi = est.: 350RWHP
                          @Bernardd:
                          Did you take a photo of the AFM in a larger tube?
                          I consider that as an alternative to the Z32-AFM.
                          • #14
                            • #15
                              yes, nistune. No i haven´t adjusted that offset because i do not understand it entirely. If i set an offset i wouldn´t read 0,45v @ idle any more, but 0,45v @ idle is ok. Could you please explain the nistune offset - thing detailed ?
                              I can try the digital volt meter and tell you the result. I once wanted to do test it like this but wires where too short and had connection problem while driving.
