surge tank location..pix needed
  • surge tank location..pix needed
    I just finished installing the turbo injectors and matching ecu in my n/a remote turbo project...it really pulls strong now.I'm trying to adapt the various other turbo parts to my car...the surge tank...anyone have a picture of where its located in a Z ???thx,mike.
    Spare tire well works good.
      Factory surge tank? hmmmmmm I don't think Z31's have one :wink:
        ok...wtf is a surge tank
          WaZZ300 wrote: ok...wtf is a surge tank
          A tank that holds fuel for when you need it at levels of high demand, or for high-G cornering.
          It's a seperate tank that is fed by the pump in the stock tank, but does not have pressure in it, rather it is simply kept full by the pump in the tank. Then another pump pulls it from the surge tank to pressurize the fuel system. This assures the second pump will ALWAYS have fuel.
            so there isn't one, correct?
              WaZZ300 wrote: so there isn't one, correct?
              I thought I said that already :?:
                sorry...The wink had me 8)
                  its shown as being mounted between pressure regulator control solinoid valve and a one way valve to the t/b on vg30et...shows it as a surge tank??black can with two vacuum lines?
                    mcx wrote: its shown as being mounted between pressure regulator control valve and a one way valve to the t/b on vg30et...shows it as a surge tank??black can with two vacuum lines?
                    Maybe for vacuum, but not for fuel. Is that what you meant?
                      ???i never mentioned either???i posted to try and find where its located.
                        surge tank FTW
                          The part you described is located in the drivers inner fender.
                          I am here to help...
                          • #14
                            Thanks Dan...the Chiltons book shows it used in 87 and later turbo applications...when mounted are the vacuum nipples pointing up or down.thx again,mike.
                            • #15
                              Since mcx is not using a earkier model turbo-ecu, he has no need for the surge tank.
                              Try not to be a Yahoo
