crowbar wrote: I have a 88T ecu that I want to run on a NA car. I plan to use your fuel injection mod where you 'over-size' fuel lines over injectors. I plan to use high resistance injectors 370cc from KA24 engines. These modded into a top feed rail from a 300zx car.
The NA car should run fine I assume? The ecu should run closed loop even though there would never be any boost in the 'load' calc? My car uses the smaller O2 sensor (like a 86 300zx NA does) and has a 3.90 rear.
Fortunately the 88-89 ECU's are very easy to install a socket/chip in.
