For those readers that actually are interested in the modification, it is necessary to understand the impact the cylinder head temperature sensor has on the operation of the car.
The sensor is just a NTC thermistor. Basically it decreases resistance as temperature increases.
The ECU modifies the fuel enrichment and ignition timing based on this sensor. It also changes the mode of injection. From Group injection to Simultaneous injection.
So the general idea is to 'lie' to the ecu about the actual cylinder head temperature. This 'forces' the ecu to run in a richer F/A ratio. It also forces the ecu to use simultaneous injection at a lower RPM then it typically would.
Some interesting points:
1. The ecu will run closed loop (O2 sensor feedback) at a 'ccol' CHTS reading. At a cold reading, it will not. I will dig up the resistance values if anyone is interested.
2. The timing is advanced when 'cold/cool' sensor readings are read by the ecu. The timing must therefore be retarded to take advantage of this. I am working on a way to actually advance retard the timing from the driver's position.
