crowbar wrote: How much do you crush the fuel pressure regulator to get Simultaneous injection?
Anyways that is besides the point. Unless you use the tps POT it will cause a very odd idle. Also you are questioning tested and proven. And furthermore i don't see the advantage of simultanious injection over squential. You are still getting the same AFR.
