Well i already did the hardware changes on the ecu, is that bad if im putting the stock MAF in a big ass pipe? If so then screw it i will just splurge for a Z32 MAF
MAF selections and hardware/wiring changes
roastin300 wrote: is that bad if im putting the stock MAF in a big ass pipe?
The way I see it the maf tube could be considered a ristriction at
say 1 bar if it is less than 200% the volume of the charge pipe.imagination is a virtue
13PsiPlease wrote: where is the z32 hardware changes located at give me a link i need the link that shows you what resistors to cut in the ecu!
440whp on pump fuel and the STOCK MAF
