Originally posted by 300zxturboftw
View Post
Nistune - Need Help
You've got to upgrade that alternator bro. 90A is weak considering the accessories you've added over time. Frontier/Xterra run 100A, Quest run 125A, Titans run 150A.. You can ether mod your mount/tensioner or attempt to swap the front casing.
Also not sure how you're running that controller, i'm more of a DIY'er and used a sentra temp switch in the radiator petcock to provide relay ground, which supplies power to high speed switch of some maxi fansLast edited by 88sinZ; 06-06-2016, 09:56 PM.
I've cut the radiator hose and put a temp switch in an adapter. Variable temp controller, but relay runs off ground. I guess I'll have to look into upgrading. Honestly all I have is 3 gauges and a boost controller. Wouldn't think that would take much.Usual Z31 suspect: Garage Queen (aka broken)
14.7 is a little lean for idle on a batch fire setup. normally the idle is most stable in the low 13 range. If you continue to have issues I would play with injector latency a bit.
lm7 swapped z
350z 6speed
s475 turbo
microsquirt ems
street car
http://www.youtube.com/user/redz31t?blend=21&ob=5
Originally posted by 88sinZ View PostIt sounds like it's 'hunting'
I see you're using the AEM UEGO. A quick search doesn't say if it has a 'dummy' signal to the ECU. If it has this feature wire it in any report back.
I wouldn't worry about the TPS values if you're running the OEM TPS, wouldn't hurt to meter it just to be sure. I'm running a stanza TPS on a Q45 TB with a wiring mod, no idle controls at all, innovate LC-1 with 'dummy' signal and it idles fine. Cams shouldn't be considered with this issue.
Did you follow the most recent NisTune setup guide? is your software up to date?2006 & 2007 Basketball National Champions! 2005, 6, & 7 Basketball SEC Champions! 2006 Football National Champions! 2006 Football SEC Champions! 2008 SEC Champions! 2008 Football National Champions! First University in history to capture three titles in a single year! I was there at all of them, and it was awesome! Go Gators!
CAG8OR - i can not confirm the 'dummy' input pin #. i have ran a 'dummy' input for roughly 1,400mi with 0 issues. i would suggest properly treating/coating your wideband ground to prevent erranious grounds as the electrical values are fairly precise.
