This may have been discussed before but I can't remember anything. Can't hurt to post it anyway. Basically I need to know the resistance values of the two resistors jwt mods for the cobra maf ecus. If someone could one end of each resistor and measure the resistance with a DMM I'd love them for it. HondaHater is severly maxing out his cobra maf and I want to make sure I have the resistors right. Thanks guys.
Someone with a JWT ecu, soldering iron, and a DMM
According to nistune, with no resistors in the ecu, the cobra maf is reading about .6 volts idling at about 1000rpm. That doesnt leave much room for bringing the voltage down but I guess it works. Were the vqmaps different between the two jwt chips?
3bar:
http://www.redz31.com/images/forum/3bar.jpg
4bar:
http://www.redz31.com/images/forum/4bar.jpg
I had them wirtten down at one point, I think I even talked to you about it... but you can see the color codes and note the cut trace and jumper for R201.
