MAF filament cleaning cycle?
  • MAF filament cleaning cycle?
    Since 280Zs had no speed sensor, I had to wire up my MAF cleaning wire through a push button switch.
    My question is how long should I hold the power button down for and how often do I need to clean it?
    I tried 8 seconds today and it seemed to run a little bit nicer after that.
    1976 280Z 2+2 Turbo
    '81 L28ET, '84 Turbo ECCS, '84-'85 rotors + Toyota 4x4 front calipers + 240SX rears, Z31 DXD Stage I clutch kit, Evo intercooler, Tokico lowering springs and HP blues
    "I drive an S30...your stock equipment is my future upgrade!"
    I think I was told like 5 seconds. as for how often every time you
    drive it.
    tbs
    Blue & Silver 81 zxt, 88 ECCS
    Z32 mas,450cc injectors
    ported exhaust manifold, cable throttle linkage
    t3/t4e 12psi , 3inch exhaust, K&N,
    ACT clutch, 240sx t/b, 1G DSM BOV
    Custom Intake FINISHED
    Ported and Polished N42
    Tan 88-89 conquest seats
    Sperco IC 18.5x6x3.5
    2.5 IC pipes
    Suspension work!!
    Nistune
    Zeitronix Wideband
    240sx transmission
    Soon:
    95 Maxima Alternator
      not all the cars with a hotwire afm even use a cleaning cycle, and someone suggested the 88+ ecus don't do it either but ....
        88+ has the wire and has it stated somewhere in the manual. I think it has the time and conditions for the clean function in the manual too but im too lazy to find it.
          5 seconds after the engine is stopped the self-cleaning operates for 1 second per the 86 FSM.
            Do not allow it to glow for 8 seconds! Well, I can sell you one if you do.
            Try not to be a Yahoo
              It's runs better than ever after doing that, but I won't do it again.
              1976 280Z 2+2 Turbo
