84T
84T ECCS
88T
88NA ECCS with 88T tune
With each pull, the timing was set to stock according to each ECCS.
The boost was set to a max of 18lbs, but it would spike at 18lbs and then fall off to about 15lbs as the RPMs increased.
Meth/water injection was used during each pull.
Basically, we tried to keep the pulls the same for good comparison.
The most obvious difference is the HP.
As notice the difference in the AFRs. Because of the leaner conditions with the 88T tune, I had severe detonation after about 3500, but as the mixture started to richen, the detonation stopped, around 5000.
The AFRs on the 84T tune started dipping into the 11s around 4000. The AFRs on the 88T tune started to dip into the 11s around 5000.
Also, the AFRs on the 84T tune dip past 10, but the AFRs on the 88T tune never clear the 10 mark.
After about 3 pulls on the second tune, we (Stinky and I) decided to modify the fuel pump at the ECCS so that it would run at 100% duty all the time. We thought this would help richen the mixture earlier in the RPMs, but it didn't make any difference in the AFRs.
My next step is to pull the tune off the 84T ECCS and put it into the 88NA ECCS. Hopefully that will give me a better, and safer place to start tuning.
Please feel free to "chime in", as long as it makes sense. :wink:
84T ECCS
88T
