s-afc install -- ECU pin help please
  • s-afc install -- ECU pin help please
    no flames necessary for using the safc, I just need your help with the ecu pins.
    I need the ECU pins/wires for rpm, knocking signal, ground, throttle signal, airflow signal and IG power.
    Thanks.
    2008 BMW E92 335i 6MT
    9 threads down from this one....read
    (check what I had to comment about on z31.com too)
    :lol:
    I am here to help...
      Red 34
      Green - 17 G/B
      Purple - 21 W
      Blue - 24 B
      white & yellow - 31B (cut 31B , white input and yellow output from apexi)
      Brown - 28B
      Black/brown - 28B 1inch away from Brown
      Edit: check and double-check everything, This is my notes from back when I used a S-AFC2 in my -85T.. And hey, No flaming needed. The AFC works great!
      http://Jocke.z31turbo.com 11.842s car
      http://www.youtube.com/watch?v=UfRwqC3jkAk
      If Nissan motorsports is Nismo, wouldn't Honda Motorsports be Homo?
        thanks guys
          Hey, did you get this installed ok man? Just curious.
          Ive been using an afc for a couple years now and its worked great!!
          Who are you to tell me my uninformed opinion is wrong?!?!?
            TODD03412 wrote: Hey, did you get this installed ok man? Just curious.
            hey todd, I haven't installed it yet...been busy at work. I'm glad to see someone else here using one, especially seeing you're in florida. You going to Z Fest?
              When, Where, WHY HAVENT I BEEN TOLD!!! HAHA
              I have been using the AFC for a few years now(stole it off my NX2000 I used to autox till an slight rollover mishap I have just recently started getting serious about making power when I started researching stuff on Z31.com and found Jasons site!!!
              For what i want to do right now it works GREAT!!!! I couldnt be happier with it. Im going to need another way to tune though when Im finished with my other motor and I put the Holset I have on..........and five speed (I dont think my auto tranny is going to last very much longer ha-ha)
                I have an safc2 as well and was wondering on the sensor type if it is # 6 and 6 after you set it to hot wire?
                  I think this should be nominated for the biggest necro of all time. I picked up the first reply from Dan-TSS and was like WHAAA???
                  88SS - #300 - http://z31performance.com/showthread.php?18360
                    But it means they searched!
                    BLOZ UP.com
