any ideas?
5V source on ECU?
BLOZ UP.com
Stinky wrote: Check the fsm. Theres a 5v source for the chts and I think theres also one for the tps?
The voltmeter seems to read unrealiably on the ECU, do you know which of the two CHTS is 5v or are they both?
CHTS
Y/G 23
B 262008 BMW E92 335i 6MT
I believe 26 is the 5v side. You can check by disconnecting it at the chts harness and check with the voltmeter there. Note the wire colors. Also try checking it with the chts connected and the engine warm to make sure it stays at 5v at all times.
Signal 12 wrote: no dice on the fsm...I don't have one.
check back every hour until the one you want is available
