Looking for a Bin file of this setup so i have something to start with thats very close. I would also like to compare the stock bin versus this to try and understand it a little better.
Also I dont know what the hell is going on but most of the .bin files i upload into livedit wont work or only the timing maps wont show up. I just hope in a few months i wont be having problems when it comes to running livedit and loading bin files into the ecu when it comes time to tune.
And since i did the hardware changes to the board on Jasons site i cant run stock tuning correct? Was thinking about loading a stock 88T file into it just to get it running first.
Lastly, say you have a tune you like and want to burn it to a chip and install it into the stock ecu socket and remove the romulator, how is that done? By hooking up an actual chip burner to the computer and burning the file onto it?
