HEY!!!! Im new to the board (I have to thank Jason for all the info!!!!! after seeing his site, my Z seems like it could really reach supercar status)
Ive got some crazy questions. I DID SEARCH..but didnt find the answer I was looking for
Pretty simple ones........if possible ?!?!?!
Im running a S-afc (for like three years now) and it works great. For right now I have been using it to tune with. Im only running 10 psi.
I finally installed a FMIC and I have Water/methanol injection and I wanted to run more boost.
Im using a walboro 255 lph pump with stock injectors
How do I know when I have reached max duty cycle with the injectors? Is there a way to meter them underload short of (this is a joke) climbing in the engine compartment while driving?
Also, at 15 psi......do you guys think the stock injectors are fine? I was going to run the 420 mercedes injectors I have read so much about. I have easy access to it. I will be using the afc to tune it though. Is this a good idea or bad idea?
Take it easy on me with the answers b/c Im so new to the part of the car.
I had no idea (until I found Jasons site and had looked around a lot on Z31.com) that we could modify and program our ecus!!!! I CANT BELIEVE HOW CHEAP IT IS TOO!!!
I know I will get a lot out of this site and I hope I can add to it!
