Napa has them.
Timing values with my Microtech
88sinZ wrote: as for heat, you could look into getting a Nismo thermostat ($60 USD from nissan). the nismo unit opens 20deg. F lower @ 170F-ish i think 67deg. C? i believe the stock thermostat is 190deg. F
i have one sitting in the garage just havent hooked it up so sorry no review on its performance
Rick - my engine is 8.3:1. I can't say that I've actually played with the high end timing on the dyno yet. I can tell you that while doing some runs on the road I had to turn down the timing and richen things up because I could hear detonation.
On the dyno I do experience a similar temperature spike during hard pulls. This seems to happen with many cars that are putting out a decent amount of power and have near stock cooling systems. I usually hit about 200F pretty quick. Of course on the highway you probably get more airflow than I do on the dyno with our giant fan and my maxima fans. I also need to try a cooler tstat.
Stinky wrote: On the dyno I do experience a similar temperature spike during hard pulls. This seems to happen with many cars that are putting out a decent amount of power and have near stock cooling systems. I usually hit about 200F pretty quick. Of course on the highway you probably get more airflow than I do on the dyno with our giant fan and my maxima fans. I also need to try a cooler tstat.
Yeah it's a 2 row turbo radiator.Kinda new.I took it off of the SS and bought a new one for the SS.I replaced the original SS radiator a while back.
I was thinking of sending the non turbo radiator to Howe or some other custom radiator shop and tell them to make an aluminum radiator with the same dimensions and a thicker 2 or 3 row core. What do you think?
Remember,I'm in Miami were it gets damn hot.Today it's like 88 FShiro #443
