if you have the ability. Sorry SDS users.
This is a 7.8:1 comp. VG30ET engine with ported heads, polished combustion chambers, ferrea valves, schneider cams and other stuff... so obviously that should be taken into consideration.
Load columns need explained.. by column testing 37 is about 0vac-1psi across most of the rev range, 64 is about 10PSI, and the edge is about 19PSI. This engine loves timing, and this is a "rough" tune using my maf bypass, so the AFR's are right around 11.0:1 under boost from ~10PSI and up. That should explain the large amount of timing under boost as well, it's actually a full 7 degrees off where I was able to hear audible detonation. The bad news is air bypasses like this are a raging b!tch to tune for. The good news is it can now run to 7K at 18PSI without running a tad lean.
The 'bumpy' spots are quite intentional.
I look forward to seeing some of you guy's timing maps, or even a rough description of how yours compares to mine and others (for the disadvantaged :-P users of systems with a control box like SDS)!
