Re: maybe stupid
Only if you need that kind of flow... I've seen data showing a 5/16 fuel line can flow over 4000cc/min or over 600whp worth of fuel. The problem is the rails and barbs, where the ID of the end of the hard line is smaller.
upgraded lines will be -6AN which are about 3/8"
CanadianZ wrote: when you run two walbros in parallel you would run two lseparate ines straight to FPR?
