Air Temp. Sensor?
  • Air Temp. Sensor?
    Can someone tell me where the air temperature sensor is on an 85 NA? I cant find it for the life of me... Its not built in to the MAF sensor is it?
    A picture of it would be excellent!
    It's built into the MAF.
    The only other fuel trimming is based on head temp and fuel temp.
      Its really a MAF trim I believe. Its not a signal sent to the ecu but an internal correction for the MAF output signal itself.
      Try not to be a Yahoo
        crowbar wrote: Its really a MAF trim I believe. Its not a signal sent to the ecu but an internal correction for the MAF output signal itself.
        Exactly correct.
          -.- Great...
          Thanks
