Turbo Elbow studs/nuts/bolts ?
  • Turbo Elbow studs/nuts/bolts ?
    Doing the turbo conversion...
    Im gonna have to buy ALL new studs, bolts, and nuts for the turbo to exhaust elbow.
    I went to Nissan dealership and they said they DO NOT make them anymore... oh well I didnt want those brittle things anyway.
    But now I have a problem.
    Where do I get these pieces? (better than OEM hopefully)
    I know im picking up the TSS Exhaust manifold bolt set...
    But How about the turbo to elbow?
    thanks!
    1SIKZ31 -86 SlickTop- R.I.P. 03/01/10 ... Parted out :-(
    ... New Project: LS1 Miata. Complete. 510whp. 2500lbs.
    1 Month Away from Rear Mount 76 --> 650-700whp.
    I am still using the ones that came with it
      go to a hardware store and look for some grade 8 bolts. if it was me, i'd get some allen bolts.
        http://moredhel.net/3z/ click on accessories, it list most of the bolts and their sizes
          M8 x 1.25 x 35mm
          *Use A4 Stainless Steel
          8)
          Dan
          I am here to help...
            Dan-TSS wrote: M8 x 1.25 x 35mm
            8)
            Dan
            Awesome, can I use bolts in place of all the studs, nut and bolts from the stock elbow?
            Like in other words can i extract ALL of the studs, and order 7 of these bolts you listed in the size you listed above and use them instead of studs/nuts/bols again?
            make sense?
            7 is the correct number correct?
              yes
                8)
                Dan
                Exactly what I did to replace two of the broken bolts. You can order them online.
                For the record the stock hardware is fine. Any material fatigues after 10,000 heat cycles....
                  Ok I just called over TWENTY (20!!) machine shops from yellowpages.com in the area of dallas, and NOT ONE could extract my studs, 80% of them said they have no idea what im talking about and they dont do that kind of work and 20% said they just cant do it.
                  One of them actually said they could for $100 PER FREAKING STUD.
                  By the way theres 5 studs on the elbow, 2 of them came out thanks god but the other 5....
                  2 are in perfect shape, and 3 are broken off in the turbine housing, BUT they ARE still sticking out about 1/4th of an inch. (all 3 are still sticking out)
                  What should I do?
                  Right now its sitting on my patio with pb blaster all over it lol.
                  thanks
                    drill and use an EZ out
                      Lance wrote: drill and use an EZ out
                      where do u buy an EZ-Out from?
                      Drill in to what?
                      the stud?
                      how do u do that?!
                        http://cgi.ebay.com/SCREW-EXTRACTOR-5pc ... dZViewItem
                        http://www.dimebank.com/tech/BrokenBolt.html
                          DO NOT use the an easy out, they only allow you to apply a small amount of torque to the broken fastener. they usually cause more problems than they fix. If you have a welder you can take care of this easily, get a nut that just fits over the fastener and weld the nut on. once it cools it will back right out with a wrench. if you don't have a welder you need to take it to a shop that does.
                            i used an easy out with great success when i replaced my head gaskets, on thing i did tho was leave what was left of the broken studs soaking with p.b blaster for a couple of days , and i drilled big wholes so i could use the biggest possible bit . if you just use the smallest of the bits, you run a big chance that you will break the easy out inside the broken stud, and that will suck to drill out)....
                              I've used easy outs for years without issue.
