A while back i took the cap & rotor off to check to see what's makes a distributor work. I'm guessing "TDC" is the larger "square" hole on the disc. If i remember right, i'm pretty sure that i can't get that to line up right because of the shaft+cam thing is really weird. I'll check it over again tonight or tomorrow.
Stinky: I have two 84T ecu's, neither have changed anything. When you say "at the pins" do you mean checking the contacts or to check them with a multimeter? I really need to get a multimeter, but i don't think i can afford a nicer one at the moment
I have it set right now where it's drivable. Drove it this afternoon - Was hesitant and slightly bucky when cold, drove fine when warm. I know this symptom points to some random sensor but i can't recall what cold bucking, and warm normal conditions point to. Hopefully someone can point out some things to check.
I don't have a multimeter, and i don't know anyone who has a timing light.
There's a lot that could be wrong with this, i know it's hard diagnosing such problems over the net but i appreciate everyones advice.
I'll try to check everything everyone has listed.
