bring the car and a blank check and we`ll get started.
the ellis autoworkz intercooler answer
I guess I just dont understand what the hell is so hard about going to home depot and spending 15-20 bucks on a 3.25" hole saw and just cutting some nice holes in the fender wells? Its not like it looks bad. And it is a hell of a lot easier than trying to run the pipes over the damn radiator. Pretty much anyone who has a z31 that has been modified to the point of needing an intercooler is capable of drilling a couple holes.
I remember when I made my very first IC pipes that went over the radiator, with pulling the bumper and everything, it took forever! with the holes that I have cut in my fender wells I made my new 3" IC pipes in about 2 - 2.5 hours tacked together(full welding not included) And with them going through the fenders i'm not soaking up heat from the radiator either.85 Z31 6.0 LSX turbo 766whp/792wtq
SATAN wrote: I guess I just dont understand what the hell is so hard about going to home depot and spending 15-20 bucks on a 3.25" hole saw and just cutting some nice holes in the fender wells? Its not like it looks bad. And it is a hell of a lot easier than trying to run the pipes over the damn radiator. Pretty much anyone who has a z31 that has been modified to the point of needing an intercooler is capable of drilling a couple holes.
Nope, congratulations you are one of the few. Now, just make a kit like that, because it looks like you have retained damn near everything stock. Fan, AC, stock tb location.
Damn! thats an old picture huh? I think I remember seeing that years ago! Looks Awsome! I still dont like the idea of the radiator heating up the IC pipe. Where is the hot pipe routed? Underneith or somthing?85 Z31 6.0 LSX turbo 766whp/792wtq
I agree that does look alot better than some I've seen, but as SATAN said heatsoak could still be an issue there I think. I think that more kits would sell if the A/C was retained too, not alot of people want to make the step in removing the A/C for the sake of the intercooler. I'm not one of those people but alot of others are...
having a car without AC was one of the worst mistakes that I've ever made. I've never removed it myself, but bought cars without it... In Atlanta, you'll end up smelling like a goat :evil:vg33et -blew some chunks outta it, then gave it all away.
2009 370z touring/nav/sports
I honestly wonder how much the radiator would heat up the pipe? I'm also thinking about all the heat that the fans blowing back into the engine bay... is it really that much of a problem? Or are you concerned more for that extra little bit?vg33et -blew some chunks outta it, then gave it all away.
I feel the same way about the heatsoak. As fast as the air moves through the pipes which have a low surface area I don't think it's going to make any noticeable difference.
The main reason we are doing the pipes the way we are is because some people just dont want to put holes in their frame. The only thing that gets cut in the entire install process is the actual pumper support which is easily replaced.
Stinky wrote: I feel the same way about the heatsoak. As fast as the air moves through the pipes which have a low surface area I don't think it's going to make any noticeable difference.
The main reason we are doing the pipes the way we are is because some people just dont want to put holes in their frame. The only thing that gets cut in the entire install process is the actual pumper support which is easily replaced.85 Z31 6.0 LSX turbo 766whp/792wtq
It could be that any improvements are simply from a longer runner... but then again, it's seriously changing the way the coolant routes and dropping the temps a significant amount. The pipes have to near the rad, and run through the engine bay any way that you want to do it...
The spearco kits ran the same way, yet they were regarded as the best kit for the car...
I've had my pipes running right over and around the rad while boosting 12-15psi on the t3, and the car overheating (turbo radiator wasn't enough for the vg33 + boost), and the pipes never seemed to be overly warm.vg33et -blew some chunks outta it, then gave it all away.
Yeah try the only kit, besides HKS which were harder to find.
