Well the previous owner had told me that the woodruff key broke and the crank pulley was spinning. I also assumed that the crank gear was spinning or moved a little. I was correct. As you can see the crank gear and the crank itself is chewed up. I need a new crank gear, crank pulley and woodruff key. My concern is that the woodruff key will not fit correctly since the left side of the crank is chewed up. Guess i will find out.....any suggestions?
